Will the Nest Protect work in my home?
Best answer: A Nest Protect will work for you as long as you're in one of the 20 countries listed below. Nest Protect is designed to work on your home's electrical service or by battery and can be used alone, in tandem with other fire alarm equipment, or with other Nest Protect units.
Amazon: Nest Protect ($124)
Nest Protect power requirements
There are two ways you can power a Nest Protect: by battery, or wired into your home's electrical service. You'll have the option to choose which type of device you need during the buying process, and as long as you buy a Nest Protect designed for your country it will work with your local electrical service.
Where do Nest products work?
Nest products, including the Nest Protect work in the following countries:
- Canada
- Mexico
- U.S.A.
- Belgium
- Denmark
- Germany
- Spain
- France
- Ireland
- Italy
- Luxembourg
- Netherlands
- Norway
- Austria
- Switzerland
- Finland
- Sweden
- UAE
- Australia
- New Zealand
Nest has the following to say about buying and using Nest products in other countries:
Be an expert in 5 minutes
Our pick
If you're replacing or adding smoke detectors, the Nest Protect is your best buy.
A smoke detector needs to warn you when appropriate, and not give false alarms. The Nest Protect excels at both and also provides excellent carbon monoxide detection. Because they're from Nest, they are easily integrated into any home automation plan and work with Amazon Alexa and Google Assistant.
Jerry is an amateur woodworker and struggling shade tree mechanic. There's nothing he can't take apart, but many things he can't reassemble. You'll find him writing and speaking his loud opinion on Android Central and occasionally on Twitter.
