A complete breakdown of Verizon's Unlimited plan and everything else you can get when you sign up for service.
In the United States, there are a lot of companies that can get you and your phone online, but most people use one of the four biggest: AT&T, Sprint, T-Mobile and Verizon. Choosing between them can be difficult. Your first priority should be what service works best in the places you spend your time. It's not worth saving $10 a month if the service is bad. Once you have that sorted, you can look at what each company has to offer and the prices they charge for it.
More: Which unlimited plan should you buy?
Let's take a look at Verizon to see what they can give you and what it will cost.
Verizon Unlimited plan details
Verizon used to have a single unlimited plan, but it has since expanded that to two, offering various levels of value depending on customer need.
Go Unlimited
Go Unlimited is the cheaper of the unlimited plans, aimed at users that don't necessarily need the fastest performance at all times or high-quality video streaming.
  • One line: $75/month
  • Two lines: $65 per line/month
  • Three lines: $50 per line/month
  • Four or more lines lines: $40 per line/month
Paper-free billing and $5/mo AutoPay discounts apply.
The Go Unlimited plan offers unlimited LTE data, but you're subject to reduced speeds (throttling) when the network is congested. Verizon may choose to throttle at any time of the billing cycle, which is unlike most other unlimited plans that only do so after a certain amount of data is used.
On Go Unlimited, all video streaming is capped at 480p on phones and 720p on tablets. And while the Go Unlimited plans offer unlimited mobile hotspot (tethering), the speed is capped at 600kbps, which is likely too slow for most people do anything other than browsing the web — slowly.
As of November 3, 2017, customers can pay $10 per line to remove streaming restrictions and have video delivered at its original resolution.
Advertisement
Beyond Unlimited
Beyond Unlimited is basically Verizon's original unlimited plan with some slight tweaks.
  • One line: $85/month
  • Two lines: $80 per line/month
  • Three lines: $60 per line/month
  • Four or more lines: $50 per line/month
The Beyond Unlimited plan offers unlimited LTE data, but you're subject to reduced speeds (throttling) at times of network congestion if you exceed 22GB in a billing cycle (customers that sign up on a two-year contract get 25GB per month before throttling).
Video streaming is capped at 720p on phones and 1080p on tablets. Mobile hotspot use is unlimited, with 15GB of LTE data in each billing cycle. Laptops or other devices used through the hotspot have a 1080p hard cap for streaming video.
Business Unlimited
Verizon is also rolling out an unlimited business plan for companies with four or more lines. Pricing is generally the same per line as the Beyond Unlimited with some minor changes.
Verizon Unlimited plan add-ons
Verizon's Beyond Unlimited plan lets you call, text and use data inside Canada and Mexico back to the U.S. at no additional charge, and call to those countries from within the States as well. Data use is capped at 500MB per day in each country, after which it is throttled to 2G speeds. The company does keep an eye on how much data you're using, though: if more than 50% of your data in a given month comes from outside the U.S., Verizon will slow down your speeds and holds the right to cut off service.
If you need other international services, Verizon has you covered.
  • The free International Messaging add-on lets you send text messages to over 200 countries and multimedia messages to over 100 countries
  • The Unlimited Together - North America add-on gives you discounted calling rates to over 230 locations for $5 per month
  • The Unlimited Together - world add-on gives you discounted calling rates to over 180 locations for $15 per month
  • A daily Travel Pass gives you unlimited data and calling when you're in one of over 100 countries for $10 per day
  • A monthly Travel Pass gives you discounted calling and messaging rates as well as a data allotment based on your needs (prices vary, see Verizon's International Travel page)
  • Cruise ship rates are $2.99 per minute for voice calls and $0.50 per message sent / $0.05 per message received for texting.
Verizon also has a program that gives you a prepaid card of up to $650 in value for a trade in if you switch from another network. The details are on the Switch to Verizon page of its website. It also has a referral program and a rewards program that can put money back in your pockets.
If you're both a Verizon Wireless and Verizon Fios subscriber, you can use the Fios Mobile App to watch your shows from home without using your data.
It also offers a wide range of its own services, including its own RCS messaging app, a personal cloud and an excellent account management app. You can find them in Google Play.
See at Verizon
Update, November, 2017: This article has been updated to reflect the recent changes made to Verizon's unlimited plans.
