If the outside of your home is in desperate need of some TLC, one critical tool you'll need to get things back in shape is a pressure washer, and today Amazon's offering the Sun Joe SPX4000 Electric Pressure Washer for just $118. Now at a new low price, this deal saves you over $30 off its average cost there; it sells for up to $189 otherwise.
Equipped with a powerful 14.5 amp motor, this electric pressure washer is capable of generating up to 2030PSI or 1.76 gallons per minute to blast away dirt, grime, and other unsightly marks you may find on the outside of your home, on your driveway, or out on the patio. Two cleaning mode are available, including Low on 1450 PSI and High on 2030 PSI which you can switch between depending on the task at hand. It's also designed with easy-glide wheels to enhance its maneuverability and comes with a 20-foot high-pressure hose, along with several other tools such as an extension wand.
With its customer reviews nearing 650 in total, this electric pressure washer has garnered a rating of 4.3 out of 5 stars at Amazon.
See at Amazon
This post may contain affiliate links. See our disclosure policy for more details.
