Adding an LED light strip behind your TV or computer monitor not only helps reduce eyestrain but also adds a unique ambiance to your room that you can customize as you see fit. The beginning of a new year is always a good time to clean up your room and make a few alterations, and you're in luck as Minger's well-reviewed DreamColor 16.4-foot LED Light Strip falls to just $20.39 at Amazon when you enter promo code MJXYBBDW during checkout. With this deal, you'd be snagging it at one of its best prices yet and close to $15 off its regular cost.
Minger's DreamColor LED Light Strip is great because you'll never lose the remote — it's app-enabled. You'll need the Govee Home app on your iOS or Android device to control it from wherever you are, similar to the Philips Hue LightStrip Plus but much more affordable. Different segments of the strip can light up differently, which is something a lot of other light strips can't do. It's waterproof and is even capable of syncing to music so that the lights pulse along with the beat. You may also want to add an extension cord to your cart if you want to set it up away from a power source.
If you're looking for a shorter, more affordable option, Minger has its 6.5-foot LED Strip Lights on sale for only $7.20 when you use promo code 484JJOJ7. That's around 50% off its regular price, though it's missing a few of the features that the above option includes.
See at Amazon
This post may contain affiliate links. See our disclosure policy for more details.
