Replace your home's wall outlets with USB-integrated versions at over 30% off
There's an easier way to keep your devices charged up without searching the house for a USB wall charger all the time. Right now, you can pick up a two-pack of Aukey's USB Wall Outlets for only $20.09 at Amazon when you enter promo code W7QYN9EV during checkout. That'll take $10 off its regular price of $30 there and snag you the outlets for $10 apiece.
Each of these wall outlets is equipped with two USB charging ports along with two standard AC outlets, letting you plug in up to four devices simultaneously without needing a power strip. The USB ports feature a total output of 4.2A per outlet, and there are also built-in safeguards to protect your devices against overheating, overcharging, and excessive current.
Aukey includes a 2-year warranty with your purchase, as well as all the hardware you'll need to replace current outlets in your home with these ones.
Alex Smith
