Neighbors is a communal app from Ring that lets its users keep track of local crime and share potential threats to others in their area. The best part? You don't need to own a Ring product to use it. Setting up a new account is easy — here's how.
Products used in this guide
Signing up for Neighbors
Once you've downloaded Neighbors from the Google Play Store, the setup process is fairly straightforward. Just pinpoint your neighborhood and sign up for a Ring account to get started.
  1. Open the Neighbors app and tap Sign up.
  2. Enter your address or find it on the map.
  3. Once you've placed your pin, tap Confirm address.
  1. Enter your first and last name and tap Continue.
  2. Enter your email address and tap Continue.
  3. Create a password with at least 8 characters.
  4. Tap Enter the neighborhood to complete your registration.
That's it! Once you've finished creating your account, you'll be taken right into the Neighbors feed where you can see recent suspicious and criminal activity in your area. You can also view the latest neighborhood crime report, which summarizes the last week of activity on one page.
Helpful hardware
One of the best parts of Neighbors by Ring is that you can still use it even if you don't actually own any of Ring's products. That being said, having a video doorbell can be a great way to keep track of your home, especially when you're not there, and you'll be able to capture footage of anything fishy to share with your community.
Surveillance made easy
Ring Video Doorbell 2
A simple and easy-to-install doorbell camera that works great with Ring Neighbors.
While not required to use the Neighbors app, Ring's Video Doorbell cameras allow you to capture and share footage of suspicious activity on your property. The Doorbell 2 can run off of either battery power or your home's existing doorbell wiring.
This post may contain affiliate links. See our disclosure policy for more details.
