How to replace the Jabra Elite 65t charging case
If you've lost your charging case for your Jabra Elite 65t or Jabra Elite Active 65t earbuds, you can purchase a replacement through the Jabra website. Here's how to pair your replacement case once it arrives in the mail.
Products used in this guide
Let's do this
Before using a replacement charging case for the first time, it will need to be synced with your current earbuds and charged for one hour.
  1. To begin syncing, place your current earbuds inside the replacement charging case.
  2. Close the lid.
  3. Wait at least an hour.
Jabra replacement parts
Flashing purple LED on the charger means the firmware is being updated. Don't open the case until the light is no longer flashing. Otherwise, wait the hour before opening the case.
Replacement parts
You can get your replacement cases for the Elite 65t and Elite Active 65t on the Jabra support website.
Bryan M Wolfe
I'm a single dad that loves everything tech. Although I'm mostly an Apple fanboy (don't hate me), you will find me writing about Android-related stuff here occasionally. Follow me @bryanmwolfe
