Best Wireless Charging Pads for Samsung Galaxy S9 in 2022
The Galaxy S9 is still a great phone in 2022, and because it supports wireless, charging you may want to stock up on wireless chargers for different rooms in your home or at the office. There are a large number of options out there for wireless charging, but not all are made equal. We've highlighted the best options that work with the Galaxy S9, including a mix of chargers from Samsung and other reputable third-party brands.
If your Galaxy S9 is still kicking, keep it juiced up with one of these chargers
Finding the right style that fits your needs
Which charger you go with will ultimately depend on your budget and design preference, but I use and recommend the iOttie iON Mini. It offers support for wireless fast charging to top up your Galaxy S9 as fast as possible. I also personally love the fabric finish and it never looks out of place whether it's on a bedside table, in the living room, or set up at my desk.
Of course, if you spend just a bit more you can snag the stylish Samsung 15W Fast Charge 2.0 Wireless Charger Stand, which is even better at a discounted price compared to the price when it first launched. It's a specifically smart option if you love using the best Samsung phones and can easily convert into a stand for better viewing angles at your desk.
Andrew Myrick
Senior Editor - Chromebooks, tablets, and wearables
Andrew Myrick is a Senior Editor at Android Central. He enjoys everything to do with technology, including tablets, smartphones, and everything in between. Perhaps his favorite past-time is collecting different headphones, even if they all end up in the same drawer.
