Best security cameras that work with Amazon Alexa 2024
Amazon Alexa is a great way to integrate your security cameras with your smart home — and these are the best.
A Wi-Fi-enabled security camera is an excellent way to keep an eye on your home while you're away. If you can find an Alexa-compatible security camera, it makes watching over your home that much easier.
For example, you can check in on the pets while you're at work, and, in the case of those with built-in microphones, quickly tell your kid that they're supposed to be studying instead of playing video games. With these cameras, you can ask Alexa to show you what is happening at any point in time and connect your cameras to Alexa routines and smart light bulbs for further home automation.
Check out these awesome security camera deals
Staff pick
Top brand
Arlo Pro cameras are some of the best money can buy, period, and they also integrate well with Alexa. The new Arlo Pro 4 carries on that legacy and expands upon it with footage now in 2560x1440 (as well as 1080p and 720p), high-powered infrared night vision, a 6500K spotlight, and a 3-6-month battery life — and no hub is required to use it.
Smart home
The sleekly designed Google Nest Cam gives you a 24/7 live stream of your home. You'll also get alerts in the Nest Aware app, with the ability to control all of your Nest products from one place. You'll also get two-way audio, and you can hide it just about anywhere, thanks to its diminutive size.
Blink out
Blink's 3rd generation Outdoor camera is reasonably priced for the feature set, offering a two-year battery life, which can be boosted to four years with a battery pack accessory. It is also weatherproof and provides two-way comms. You can store files locally with the Blink Sync Module 2, or you can take advantage of Blink's affordable cloud storage plans.
Integrated security
For 24/7 professional monitoring, the Ring Spotlight Cam Plus Wired is your best option since Ring offers Protect plans. These cameras also have full HD live streaming and recording, two-way audio, night vision, and lifetime purchase protection from Ring. Plus, stolen cameras are covered.
Blink in
The Blink Indoor (3rd Gen) camera shares all of the company's Outdoor cam's specs and features, minus the weatherproofing. This accounts for the price difference, so if you don't need weather resistance, this is a solid and more affordable Blink alternative for your indoor or sheltered spaces.
Indoor or outdoor
I've really enjoyed using this wired security camera because it can be great inside or out with its wide-angle 2K HD live-streaming footage, and you can record 24/7 and save it all to a microSD card. If you want cloud storage, Kasa offers that too! You'll even get a flood light to make sure you get a perfect image day or night.
Little one
While this is a wired-only camera, it offers many of the same features as the pricier Blink Indoor camera at a fraction of the price. It's super simple to set up and get started, and it's easy to use with your Echo Show or Fire TV devices. Plus, you can use the Blink Add-On Sync Module 2 to store your video files locally.
Budget pick
The latest Wyze Cam v3 comes with all the great features of the favorite v2 camera plus the bonus of 1080p color night viewing thanks to its impressive Starlight Sensor. Also, unlike its predecessor, it's water-resistant with an IP65 rating, so you can use it both indoors and outdoors. Wyze did suffer from a security vulnerability in 2022 but has patched it for devices like the Cam V3.
Pan and tilt
Another budget option, Wyze Cam's Pan V2, has a 360-degree horizontal range and a vertical range of 93 degrees. When it detects motion, it'll even follow the target and tag it within its field of view. You get 14 days of rolling cloud storage from alert video, which is 180p at 15FPS. It also offers many of the features found in the Cam v3. This camera also received the security patch as the Wyze Cam V3 did.
The best security solutions for your smart home
The best Alexa devices combine excellent features with ease of use and convenience. For a great Alexa-compatible security camera, you really can't go wrong with the Arlo Pro 4. Though it is on the expensive side, with its excellent feature set, and solid Alexa integration, it is a winner.
If you're looking to complement your Ring Video Doorbell, then you'd do well to pick up the Ring Spotlight Cam Plus Wired. The Ring Protect plans are inexpensive, and they come with other awesome features, like Ring Neighborhoods, which send you real-time crime and safety alerts from other Ring users in your area. Plus, you'll have all of your smart security taken care of in one app.
Be an expert in 5 minutes
Olivia Lipski is a freelance writer for Android Central and loves testing out the latest smart home tech and discovering the best cell phone plans. When she's not busy running around NYC trying to find great food or coffee, she's in her kitchen trying to make it herself.
