Best Controllers for the Amazon Fire TV
Looking to invite friends over for a multiplayer session on your Amazon Fire TV but not sure what controllers are compatible with it? Whether you have a first-generation Fire TV, a 4K Fire TV dongle, or the new Fire TV Cube there are a variety of Bluetooth game controllers available.
We've broken out a list the best controller options for the Amazon Fire TV — and chances are you may already own one that's perfectly compatible.
Amazon Fire TV Gaming Controller
Amazon Fire TV Bluetooth controller
An obvious but necessary inclusion on this list, if you enjoy the gaming controller that came with your Amazon Fire TV Gaming Edition, you can buy extra controllers from — where else — Amazon.
The Amazon Fire TV controller connects via Bluetooth and has a number of features specifically designed to get the most out of your Amazon Fire TV box. For starters, it includes a built-in microphone, which gives you full access to Alexa features and allows you to search for games, movies, music, and more information, using only your voice.
The controllers also feature a headphone jack, so you can fully immerse yourself in a movie or game without bothering the people around you. This will also be your best option if you have a second generation Fire TV, as support for third-party game controllers with the newer Amazon box is spotty at best compared to its predecessor.
The Amazon Fire TV controller takes two AA batteries, so you should stock up on those if you plan on becoming a heavy gamer. Get yours for just $49.99 from Amazon (where else?).
See at Amazon
SteelSeries Stratus XL
The SteelSeries Stratus XL is a great controller that works for gaming on your Windows PC, Android phone, and Amazon Fire TV. SteelSeries has basically taken the best features from the DualShock and Xbox 360 controllers and combined them to create the Stratus XL.
It connects via Bluetooth and plays for up to 40 hours on two AA batteries. It's perfectly weighted and has been designed to fit comfortably in your hands for marathon gaming sessions.
Best of all you can get this great controller for just $40. This is a great controller for any Android gamers so you won't want to miss out on a good deal.
See at Amazon
Xbox 360 Wired Controller
Microsoft Xbox 360 Wired Controller
The wired version of the Xbox 360 controller works nearly flawlessly with the first generation of Amazon Fire TV. Simply plug in the controller to the USB port on the back of your Amazon Fire TV and you're good to go. With the second generation, you may need to go into settings and ensure that USB debugging is turned off before the system will find the controller.
Looking to attach more than one USB controller? It's as simple as first plugging in a USB hub then plugging in up to four controllers. If you've got a couple plugged in, you'll even notice the player indicator lights will light up properly — a small but reassuring feature.
There's a whole bunch of third-party controllers that work with the Amazon Fire, including the wireless versions of the Xbox 360 controllers, but the reason why we're not recommending the wireless variant is that you'll also need to own Microsoft's Xbox 360 Wireless Receiver for Windows.
If you happen to already have a few of the wireless Xbox 360 controllers around, the dongle receiver may be the better option. If you don't, the wired variety is your best bet, as you won't have to worry about batteries or connectivity issues. At this point, they must be considered collector's item because Amazon is selling them for $65.
See on Amazon
DualShock 4 Bluetooth Controller (for PS4)
PS4 DualShock 4 Bluetooth Controller
The DualShock controller has been an industry standard and trailblazer since first being introduced for the original PlayStation back in 1998. While the technology inside the controller has improved, the overall design has remained largely unchanged and it's clear to see why — it's incredibly comfortable to hold.
Sony's DualShock 4 Bluetooth Controller is a great option that's compatible with your Amazon Fire TV. It's quick to pair — simply go into the Amazon Fire TV's Bluetooth controller settings, then hold down the Share and PS button on the DualShock controller to start the pairing.
The DualShock 4 controller is a surprisingly versatile controller; beyond using it with your PS4 and Amazon Fire TV, it's also compatible with Windows for PC gaming. Get yours for $57 on Amazon.
See at Amazon
Matricom G-Pad BX Wireless Gamepad
There's a number of features that make the Matricom G-Pad a compelling third-party Bluetooth controller to buy for your Amazon Fire. For starters, it's powered by a rechargeable lithium-ion battery which means you won't need to stock up on AA batteries, and if you're running low you can plug the mini-USB cable to your Amazon Fire and play wired.
Since it's Bluetooth, it'll work just fine with your Samsung Gear VR, other Android devices and, of course, Matricom's own G-Box Android TV box. It features dual modes for control, so you can switch over to mouse emulation whenever you may need it. Best of all, it's the cheapest controller on the list offering at just $17.50, yet is quite comfortable and lightweight for a budget price. Given its near-universal compatibility and simple-yet-conventional design, Matricom's G-Pad Wireless gamepad is worth your attention.
See at Amazon
Logitech Gamepad F310
If you're looking for a cheaper USB controller option, the Gamepad F310 from Logitech is a good choice.
It features the same analog stick layout as the DualShock and a cord that should be long enough to reach from the Amazon Fire TV to the couch. This one is also plug-and-play, meaning you shouldn't have to worry about setting things up.
And since this is a cheaper option, starting at around $25, you could stock up on a couple of them, along with a decent USB hub and always be prepared for some multiplayer action.
See at Amazon
What's your preferred controller?
Do you have a favorite Amazon Fire TV gaming controller that didn't make our list? Tell us about it in the comments!
Update July 2018: Updated pricing information and reordered our list. These are still the best options for the Amazon Fire TV.
Amazon Fire TV
Main
Buy at Amazon
This post may contain affiliate links. See our disclosure policy for more details.
