Best Car Chargers for Galaxy S8
The Samsung Galaxy S8 is one of the most popular phones of 2017 and for good reason. Beyond it's beautiful design, it's packed with high-end specs, including a more efficient processor that helps extend the battery life of your device.
As efficient as the S8 battery is, it's always good to have chargers available at home, at work, and also in your car. The S8 supports Adaptive Fast Charging and Qualcomm's Quick Charge technologies, so you'll want a car charger that takes advantage of those features.
Here are some of the best options you should consider!
Samsung Adaptive Fast Car Charger
If you're concerned with compatibility issues, you may want to consider this accessory from Samsung. This charger is a few years old — originally released alongside the Galaxy S6 — but if you're looking for something specifically for your Samsung phone, this is the way to go.
The single USB port is less than ideal if you've got multiple devices requiring charging or want to be able to offer your passenger a port to charge their phone as well. If that's a dealbreaker, Samsung also offers a dual-port car charge, though it's twice the cost of the single-port charger. Either way, if you trust first-party accessories for your phones it's worth checking out something directly from Samsung.
Grab it for around $12 from Samsung.
See at Samsung
Anker PowerDrive 2
Anker is one of the most trusted brands when it comes time to charge your phone, and the PowerDrive 2 is one of the best car chargers you can buy, earning accolades from the Wirecutter as the best USB car charger you can buy.
The PowerDrive 2 sports two USB ports and while it doesn't support Qualcomm Quick Charge, it instead uses Anker's proprietary PowerIQ and VoltageBoost technologies to offer up to 4.8 amps or 2.4 amps per port, which both can be used to charge two devices simultaneously.
Available in your choice of black or white and backed by Anker's 18-month warranty, you can get the PowerDrive 2 for under $15 on Amazon.
See at Amazon
Tronsmart Dual USB Car Charger w/ Quick Charge 3.0
This car charger from Tronsmart includes a USB-C port that's Quick Charge 3.0 compatible. That means you'll need a USB-C to USB-C cable to take full advantage of the charging speeds.
This charger offers great compatibility as you'll be able to fast-charge your Galaxy S8 and other devices that use USB-C, while the included USB-A port allows you or your friends to also charge their older devices, too, although not at rapid charging speeds. But not you — you'll be charging in the fast lane with your Galaxy S8!
Tronsmart backs its product with a 18-month warranty and you can find it on Amazon for under $12.
See at Amazon
Aukey Flush Fit Dual Port Car Charger
A common problem with car chargers is the placement of the 12V socket or cigarette lighter within specific cars. Sometimes they're found on or tucked away below the dash or built into the center console armrest. Depending on its placement, you may not have a lot of space for a bulky car charger.
That's where the Aukey Flush Fit Dual Port Car Charger comes in. While it doesn't support Quick Charge for the speediest of charge times, it still pumps out 2.4 amps per port. Most importantly, it's small and subtle enough to sit flush in pretty much any car. If aesthetics are more important to you than maximized charge times, or you've struggled with bulkier car chargers in the past, give Aukey's Flush Fit Car Charger a try — available for under $10.
See at Amazon
How do you keep your GS8 charged on the go?
Do you use any of the car chargers on our list? We want to hear your opinions on them! Let us know in the comments below!
Marc Lagace
Marc Lagace was an Apps and Games Editor at Android Central between 2016 and 2020. You can reach out to him on Twitter [@spacelagace.
