Best Bluetooth trackers 2024
Never lose a thing ever again with the best Bluetooth trackers.
1. At a glance
2. Best overall
3. Best for keys
4. Best for pets
5. Best flat sticker
6. Best design
7. Best for wallets
8. Best small sticker
9. Best for Samsung
10. Best for Apple
With one of the best Bluetooth trackers, you'll never have to worry about losing your keys, wallet, or many other valuable items. These tracking gadgets can be attached to your keys, bags, and an assortment of other things and make it easy to keep tabs on them using a companion app that lets you find them in little to no time.
Tile continues to dominate this market despite facing competition from new players all the time. Unsurprisingly, our favorite Bluetooth tracker is still the Tile Pro. And the more recent version, which was introduced in 2022, offers an unbeatable range, the loudest alert, and a one-year replaceable battery. That said, you also have a range of other options.
At a glance
Best overall
Best overall
The excellent Tile Pro (2022) has a replaceable battery that lasts for up to a year, durable IP67 rating, and a wide 400ft Bluetooth range. It costs a little more, but you get a ton of useful features that are worth the asking price.
Best for keys
Best for keys
The Tile Mate (2022) has it all: three years of battery life, water and dust resistance, Google Assistant compatibility, and even a button. There's a scannable QR code on the back if the battery runs out and the beeper is reasonably loud too.
Best for pets
Best for pets
Although it isn't as robust as Tile's offerings, the Chipolo One (2020) is ideal for pets because it's so small and lightweight. The hole is perfect for pet collars and the speaker is extremely loud, making it easy to locate.
Best flat sticker
Best flat sticker
Looking for a super thin tracker that also sticks to surfaces? We suggest the Cube Shadow. It's the best flat Bluetooth tracker as it has all those properties. The battery is rechargeable, and this thing has IP67 water and dust proofing too.
Best design
Best design
Not many Bluetooth trackers are as stylish as the Nut Find3. It's more than just a pretty face, as it's equipped with a replaceable battery and sports cool features like Smart Anti-Loss and Group Control.
Best for wallets
Best for wallets
The sleek Tile Slim (2022) is unbelievably thin, almost as thin as a biscuit if you'll believe it! Yet, it has a speaker, a QR code, and is waterproof. Oh, and the card-like design makes it perfect for just about any wallet.
Best small sticker
Best small sticker
This teeny tiny little sticky tracker from Tile is waterproof, long-lasting, and offers a lot of durability. It features a loudspeaker as well, and the small size and roundness make it very versatile.
Best for Samsung
Best for Samsung
If you're rocking an S series Samsung Galaxy phone, the Galaxy SmartTag+ is the best Bluetooth tracker for you. Users can take advantage of extras that other Android users can't access, such as UWB support. It even excludes lower-level Samsung phones!
Best for Apple
Best for Apple
Apple users are likely to gravitate toward this first-party option. The Apple AirTag can only be used with iOS devices and comes with bonus features for those deep into the Apple ecosystem.
Best overall
Reasons to buy
Reasons to avoid
One of the most important factors to consider when choosing one (or more) of the best Bluetooth trackers is range. This is the distance from which the tracker can be found through your smartphone app. Most people shopping for a tracker are going to look for the largest range possible. While many options in the market have around 100 to 200 feet of range, the new Tile Pro beats those numbers by a long shot. It's also smooth and sleek now, as opposed to the textured surface of the previous-gen model.
You'll get an amazing 400-foot range, which is just one of the reasons it's the best overall choice. It also promises the loudest ring, a one-year replaceable battery, and compatibility with Amazon Alexa and Google Assistant. Both iPhone and Android users can enjoy the Tile Pro with the corresponding Tile app. You'll also get access to the biggest lost-and-found community, which means anyone using the Tile app that's within range of your lost item can update its location for you. This model features a new Lost and Found function via a QR code on the back that can be scanned by anyone who finds one but isn't a Tile user. They will get your contact information so they can return it to you.
With the Tile Pro, you also have the option of upgrading to a two-pack or a four-pack. The newest Tile Pro fits nicely on a key ring thanks to the more rectangular shape and boasts an IP67 rating for full water resistance. That's even better than the Galaxy SmartTag!
Best for keys
Reasons to buy
Reasons to avoid
The Tile Mate offers a nice blend of helpful features and portability. Battery life has been increased to three years, but there's one caveat: the battery is no longer user- replaceable, which means you'll have to replace it after that time. It's a bit bulkier than some of the other trackers, but the Tile Mate is still compact enough that it can fit comfortably in most wallets and purses. It also comes with a keyhole, which is great for attaching to your keys, luggage, backpacks, and so on. And you can now get it in black as well as white.
You get an improved range of 250 feet with the new Tile Mate, which is also more rounded than the previous generation model, along with the new Lost and Found feature with a QR code so anyone who finds it can get your contact information. It's also the second loudest option offered by Tile. When you combine these features, you can feel confident that you'll be able to locate your Tile Mate without a problem. This tracker also gives you convenient access to the Tile lost-and-found community, which is always good to have. Like the Tile Pro, it also has an IP67 rating for total water- and dust resistance.
You may be compromising slightly when it comes to the range and the volume, as well as the fact that you can't swap out the battery. But it isn't a bad trade-off for the lower price tag. Not to mention, you can also pick a four-pack, which is an even better value if you're looking to stock up on Bluetooth trackers.
Best for pets
Reasons to buy
Reasons to avoid
This colorful Bluetooth tracker is shaped like a circle rather than a rectangle or square, standing out from the rest. However, it's still relatively slim and won't be too bulky to carry around with your items. You can also use it to find your phone. All you have to do is double press it, which will make your phone ring even if it's on silent.
With Chipolo's Web service, you can see each tracker's location and your phone or tablet from any web browser. If you've lost track of an item, you can access the community search to mark it as lost. The Chipolo One is IPX5 rated as well, so it can withstand some of the elements.
Unlike previous versions, you can replace the battery (which should last up to two years). It's worth noting that Chipolo has fewer users than Tile, so the crowd-finding system with community searching isn't as reliable as the more popular Tile app.
Best flat sticker
Cube Shadow
Our expert review:
Reasons to buy
Reasons to avoid
If you've been searching all over for a Bluetooth tracker that you can recharge instead of having to replace the battery, look no further than the Cube Shadow. What's more, a single charge can last two months, and the USB charger is included with your purchase.
In addition to reusing and recharging your tracker, the Cube Shadow also promises a generous 200-foot range, 100-decibel alert, and an IP67 rating. This means it can be immersed in water up to one meter for up to thirty minutes without sustaining any damage. The button on the tracker will ring your phone when you can't find it. You can also use this button to take pictures or videos with your phone's camera.
This Bluetooth tracker might be a bit pricey compared to others. You also only get one tracker in the package, but it's more than worth it for all the features it offers. It also lacks a keyhole, so it's not ideal if you are hoping to loop it into your key ring. However, the Cube Shadow does come with an adhesive that lets you stick it to most items.
Best design
Nut Find3
Our expert review:
Reasons to buy
Reasons to avoid
The Nut3 Smart Key Finder is the perfect choice when you need a tracker that can do it all. More specifically, this Bluetooth tracker offers a total of six different functions: One Touch Find, Find Your Phone, Smart Anti-Loss, Left Phone Alert, Lost and Found Network, and Group Control. Lost track of your phone? Simply press the button on your Nut 3 to ring your phone.
Many of these features are self-explanatory, but a few interesting ones are worth elaborating on, such as the Smart Anti-Loss feature that alerts you if you leave your wallet behind somewhere. Group Control allows your family to track your Nut3, too. Finally, if you leave your phone behind when you're outdoors, an alert will sound to inform you.
While the Nut 3 claims to offer a 150-foot range, this has exceptions. For example, when using it outside, you can expect a range of 30 to 50 meters. However, when it comes to indoor use where walls are present, the range is around 10 to 30 meters. With all the functions the Nut3 offers, you can expect to receive many notifications to go with it, which might be annoying for some users. You have the option of a 4-pack, 2-pack, or 1-pack.
Best for wallets
Reasons to buy
Reasons to avoid
If you're already a fan of the Tile ecosystem and looking for the thinnest option, you will love the new Tile Slim. This tracker resembles a credit card's size and shape, so it's ideal for when you need a tracker that can fit in tight spaces. This makes it ideal for keeping tabs on your wallet, as it'll fit right into a credit card slot. The range has been increased to 250 feet with the addition of the Lost and Found QR code feature, so someone who comes across it who isn't a member of the Tile family can acquire your contact details, plus it has a louder ring than the previous-gen model.
Some pretty neat features of this ultra-slim tracker include community finding, Alexa and Google Assistant compatibility, and the option to ring your phone by pressing a button on the Tile. Whether you're keeping track of your wallet, purse, or passport, this is the ideal Bluetooth tracker for the job. Did we mention it's waterproof, with the same IP67 rating as the others, and comes with a built-in battery that lasts three years?
This Tile tracker is a worthy contender for those who want a slim wallet tracker that offers plenty of features. The Tile Slim does not come with a replaceable battery, but you can participate in the discount reTile program when the time comes for a new one.
Best small sticker
Reasons to buy
Reasons to avoid
To round out its lineup, Tile has the Sticker. This Bluetooth tracker is as tiny as ever, which makes it perfect for household items. Some of the other trackers are a little more restrictive in how you can use them, either by their shape or a key ring. With the Sticker, that's not the case. You can stick it onto anything you want to track as long as it has a dry surface. So, whether that's a remote, cellphone, laptop, wallet, or passport, the Tile Sticker can track it.
At 250 feet, it has the same range as the other new Tile trackers. But, of course, you'll still have access to the lost-and-found community if you want to take a chance putting it on more valuable items that leave the house. The Tile Sticker (2022) also has a button that allows you to find your phone and a louder ring than the original model.
At this small size, you won't get a replaceable battery, but you do get up to three years of battery life before it needs to be replaced. Not surprisingly, that's the same amount of time the adhesive developed by 3M is supposed to last. If you need to remove the Sticker for some reason, it may take a bit of effort, but it will eventually come off. It's also fully water-resistant with an IP67 rating like the other new 2022 models in the lineup.
Best for Samsung
Reasons to buy
Reasons to avoid
The Galaxy SmartTag+ is Samsung's answer to Apple's AirTag line of Bluetooth trackers. As expected, only Samsung phone users can use the Galaxy SmartTag+ trackers. To make matters worse, this pricey tracker's best features are compatible with select Samsung flagships alone.
If you do have a top-of-the-line Samsung phone that can take advantage of all of this tracker's cool features, you're in luck. The Samsung Galaxy SmartTag Plus makes good use of its Ultra-Wide Bandwidth (UWB) functionality and the wide network of other Samsung users to deliver extremely precise tracking. The Bluetooth range on this thing is 120m and it also comes with IP53 water and dust resistance.
You can add the Galaxy SmartTag+ to your Samsung SmartThings ecosystem and allocate a custom function to the physical button on the SmartTag+. Locating the Bluetooth tracker is easily done through Samsung's SmartThings Find app or the AR Finding function in the camera. The included lithium battery lasts for one year and after that you can simply replace it yourself.
Best for Apple
Apple AirTag
Our expert review:
Reasons to buy
Reasons to avoid
Apple has joined the Bluetooth tracker market with the AirTag and unsurprisingly, it's exclusive to iOS device owners, working with the existing Find My ecosystem and app. The round, stainless-steel tracker is water and dust resistant and will ring when you need to find whatever item it's attached to, be it your keys, gym bag, or wallet. It is worth noting that you'll have to buy a separate loop or key ring accessory to clip it to keys or a purse strap. Siri can also be summoned to help you find a valuable item you have misplaced.
If you're within Bluetooth range, the AirTag will ring. If not, it will use Apple's Find My network to pinpoint its location. If someone finds your belongings, they can even tap it using any NFC-enabled device and be directed to a website with your phone number (if you provided it) so they can call and let you know you left your office keys at the local pub, or your wallet at the grocery store checkout.
With a replaceable battery and simple pairing with an Apple device, it's a solid choice for those invested into the Apple ecosystem. However, as mentioned before, it won't work with Android devices, though Android device owners can return a lost AirTag to its rightful owner by logging into the website and getting their number using an NFC-enabled non-Apple device.
Select the right Bluetooth tracker for your needs
Just as a good password manager can protect your digital assets, a good Bluetooth tracker can help you stay close to your physical assets. Any of the Bluetooth trackers on this list will serve you well.
Despite lots of competition and variations from the brand itself, we're still calling the Tile Pro our favorite, thanks to its incredible range of 400 feet, extremely loud alerts, and a replaceable battery that lasts for one year. So, if range is the most important factor in a tracker for you, you really can't go wrong with this one. No other tracker comes close to offering the kind of range that the Tile Pro has.
There are plenty of trackers to choose from that will let you keep close tabs on your personal belongings. So, whether you tend to leave your wallet behind or are known for misplacing your keys, these are some of the best Bluetooth trackers that'll make things a lot easier.
Be an expert in 5 minutes
Namerah enjoys geeking out over accessories, gadgets, and all sorts of smart tech. She spends her time guzzling coffee, writing, casual gaming, and cuddling with her furry best friends. Find her on Twitter @NamerahS.
- Courtney Lynch
- Christine PersaudContributor
