How do I use Multi Window mode on Samsung Galaxy S7?
Although Android 7.0 Nougat offers native multi window support for all phones, Samsung's Galaxy series of phones have been able to use Multi Window mode for years now. This multi-tasking feature is extremely useful for people who are tired of moving back and forth between apps.
Note: This article was last updated in November 2016 with new information.
How to enable Multi Window mode on Galaxy S7
Not all apps are capable of using Multi Window mode, so only Multi Window-compatible apps will appear when you activate Multi Window mode.
  1. Press and hold the Recents key. It's the button to the left of your Home button.
  2. Open the first app you want to use.
  3. Open the second app you want to use. Note: you can't open the same app twice.
    Press and hold the Recents key, open the first app you want to use, and then open a second app.
The app that you are currently in will always have a blue outline around the edges, so you shouldn't lose track of where you are.
How to enable Multi Window mode in from Recents menu on Galaxy S7
If you already have the app you want to use Multi Window mode open, you can easily start a Multi Window session from the Recents menu.
  1. Press the Recents key. It's the button to the left of your Home button.
  2. Tap the Multi Window mode button on the app you want. It looks like to rectangles stack on top of each other. This button will only appear on apps that support Multi Window mode.
  3. Tap second app you want to use.
    Press the Recents key, tap the multi-window-button on the app you want, and then tap on the second app you want to use.
How to enable Multi Window mode from an app on Galaxy S7
If you are already in an app and want to start a Multi Window session, you can do so with just a few taps provided the app you have open supports Multi Window mode.
  1. Launch any app from your Home screen or app drawer.
  2. Press and hold the Recents key.
  3. Tap on the second app you want to open.
    Launch any app from your Home screen or app drawer, press and hold the Recents key, and then tap on the secodn app you want to open.
How to adjust the size of the Multi Window mode windows on Galaxy S7
  4. Press and hold the white circle in the middle of the two app windows.
  5. Drag the white circle to the spot you want.
  6. Let go.
    Press and hole the white circle in the middle of the two apps, drag the white circle to desired position, and then let go.
How to invert the app windows' positions in Multi Window mode on Galaxy S7
You can quickly invert the positions of both apps that are open in Multi Window mode. Not only will they switch positions, but the windows will also switch sizes.
  4. Press the white circle in the middle of both apps
  5. Press the invert positions button. It's the furthest left button in the Multi Window menu.
    Press the white circle in the middle of the two app windows, and then tap on the invert positions button.
How to drag and drop content in Multi Window mode on Galaxy S7
Some apps — fair warning it's a limited list— will allow you to drag and drop content between them when you have them in Multi Window mode. If you try it with two apps that aren't supported, your Galaxy S7 will let you know.
    Launch any app from your Home screen or app drawer, press and hold the Recents key, and then tap on the second app you want to open.
  4. Tap on the app window you want to drag and drop content from. The app you have selected will be surrounded by a blue border.
  5. Tap the the white circle in the middle of the two app windows.
  6. Tap on the drag and drop content button.
    Tap on the app window, tap the white circle, and then tap the drag and drop button.
From here you can now drag the content on the app window you have selected to the other app window.
How to minimize an app in Multi Window mode on Galaxy S7
  4. Tap on the app window you want to minimize. The app you have selected will be surrounded by a blue border.
  6. Tap on the minimize button. It's the two arrows facing pointing towards each other in a box.
    Tap on the app window you want to minimize. tap on the white circle, and then tap on the minimize button.
How to maximize an app in Multi Window mode on Galaxy S7
  4. Tap on the app window you want to maximize. The app you have selected will be surrounded by a blue border.
  6. Tap on the maximize button. It's the double-sided arrow in the box.
    Tap on the app window you want to maximize. tap on the white circle, and then tap on the maximize button.
How to close an app in Multi Window mode on Galaxy S7
  6. Tap on the close button. It looks like an X.
    Tap on the app window you want to maximize. tap on the white circle, and then tap on the close button.
